0xBC | 0x09 | bcZRanger | Z-Ranger | 1.3g | ~15mA | Below | link | link |
0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | link | link |
0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A |
0xBC | 0x0C | bcMultiranger | Multi-ranger | N/A | ~90mA (depending on mode) | Above | N/A | N/A |
0xBC | 0x0D | bcMocap | Mocap marker deck | N/A | 0mA | Above | N/A | N/A |
bcFlow | X | X | (X) | X | X | X | X | VCC | ||||||||
bcOA | X | X | VCC | |||||||||||||
bcMultiranger | X | X | VCOM | |||||||||||||
bcMocap | (X) | (X) | N/A |
