The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable “range.range” but is not used by the firmware internal algorithm.
To enable altitude control using the Z-ranger, the Crazyflie firmware has to be recompiled with the following config.mk:
ESTIMATOR=kalman CFLAGS += -DUPDATE_KALMAN_WITH_RANGING -DKALMAN_DECOUPLE_XY
The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly drift. If that happens bring it down to the detection range.
