breakout:flow [2017-07-07 09:40] arnaud [PMW3901 optical flow sensor] |
breakout:flow [2021-06-24 16:16] (current) kimberly |
====== Flow breakout board ====== | ====== Flow breakout board ====== | ||
Line 4: | Line 9: | ||
===== Functional description ===== | ===== Functional description ===== | ||
Line 25: | Line 31: | ||
+ | ===== Arduino drivers ===== | ||
+ | You can install Arduino libraries using the [[https:// | ||
+ | The VL53L0x has been succesfully tested with the following drivers: | ||
+ | * [[https:// | ||
+ | The PMW3901 arduino driver is [[https:// | ||
Line 32: | Line 47: | ||
* Mechanical specification: | * Mechanical specification: | ||
* Weight: 2.7g | * Weight: 2.7g | ||
- | * Size (WxHxD): | + | * Size (WxHxD): |
+ | ===== Schematic ===== | ||
+ | Flow breakout schematic: {{ : | ||
