breakout:flow [2017-07-07 10:18] arnaud |
breakout:flow [2021-06-24 16:16] (current) kimberly |
====== Flow breakout board ====== | ====== Flow breakout board ====== | ||
Line 4: | Line 9: | ||
===== Functional description ===== | ===== Functional description ===== | ||
Line 25: | Line 31: | ||
+ | ===== Arduino drivers ===== | ||
- | ===== Specification ===== | + | You can install Arduino libraries using the [[https://www.arduino.cc/ |
- | {{:breakout: | + | |
+ | The VL53L0x has been succesfully tested with the following drivers: | ||
+ | * [[https:// | ||
+ | The PMW3901 arduino driver is [[https:// | ||
* [[http:// | * [[http:// | ||
* PMW3901MB Optical Motion Tracking Chip ({{ : | * PMW3901MB Optical Motion Tracking Chip ({{ : | ||
Line 35: | Line 48: | ||
* Weight: 2.7g | * Weight: 2.7g | ||
* Size (WxHxD): 20x26x4mm | * Size (WxHxD): 20x26x4mm | ||
===== Schematic ===== | ===== Schematic ===== |
