doc:crazyflie:api:firmware:deck [2015-08-27 14:14] arnaud created |
doc:crazyflie:api:firmware:deck [2015-12-09 15:39] arnaud [Deck API] |
Line 7: | Line 7: | ||
* Optionally provides a task to run in (arduino-like setup and loop) (//not started yet//) | * Optionally provides a task to run in (arduino-like setup and loop) (//not started yet//) | ||
+ | If you want to get started you can follow the [[doc: | ||
===== Deck drivers ===== | ===== Deck drivers ===== | ||
Line 61: | Line 62: | ||
The deck driver will be initialized only if a deck is connected with the right | The deck driver will be initialized only if a deck is connected with the right | ||
OW memory content. During development it is possible to force the initialisation | OW memory content. During development it is possible to force the initialisation | ||
- | of a deck by adding a define in ```config.mk```: | + | of a deck by adding a define in ```tools/make/config.mk```: |
<code make> | <code make> |
