doc:crazyflie:api:python:index [2015-07-15 16:31] 127.0.0.1 external edit |
doc:crazyflie:api:python:index [2015-10-13 11:58] arnaud [Logging] |
Line 256: | Line 256: | ||
- | The datatype | + | The datatype |
* float | * float | ||
* uint8_t and int8_t | * uint8_t and int8_t | ||
* uint16_t and int16_t | * uint16_t and int16_t | ||
* uint32_t and int32_t | * uint32_t and int32_t | ||
- | * FP16 (this is a fixed point version of floating point) | + | * FP16: 16bit version of floating point, allows to pack more variable in one packet at the expense of precision. |
The logging cannot be started until your are connected to a Crazyflie: | The logging cannot be started until your are connected to a Crazyflie: |
