doc:crazyflie:bootloader:client [2015-03-09 14:23] arnaud created |
doc:crazyflie:bootloader:client [2020-05-12 14:26] (current) kimberly |
| + | ======Bootloader client implementation ====== | ||
| + | ====== Bootloader file format ====== | ||
| + | In order to make bootloading easier across platforms the different firmwares are packaged together in a ZIP file that contains a manifest describing which files are used for what. Here's an example of a manifest, it should be called // | ||
| + | Each entry in the file describes one file, with the following attributes: | ||
| + | | **Attribute** | **Values** | **Comments** | | ||
| + | | platform | ||
| + | | target | ||
| + | | type | fw, bootloader, softdevice, userapp | Describe what's contained in the binary | | ||
| + | | origin | ||
| + | Currently only platform=cf2, | ||
