doc:crazyflie:bootloader:index [2014-12-08 09:44] macke |
doc:crazyflie:bootloader:index [2015-07-15 16:31] 127.0.0.1 external edit |
+ | ====== Crazyflie bootloader ====== | ||
+ | The Crazyflies have a radio bootloader pre-programmed. It allows to flash all firmwares over the air using Crazyradio. The boot loaders cannot erase themselves so it is always possible to restart the Crazyflie in bootloader mode. | ||
+ | For technical documentation go to: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ====== Entering bootloader ====== | ||
+ | The bootloader can be entered in two ways: Cold-boot and warm-boot. | ||
+ | ===== Cold booting ===== | ||
+ | The procedure to cold-boot the bootloader depends of which Crazyflie you are using. | ||
+ | For Crazyflie 1 start the bootloading sequence on the PC and restrart the Crazyflie. | ||
+ | For Crazyflie 2, press the ON/OFF switch more than 1.5 second until the blue led blinks. Then release the button and the two blue leds should blink. | ||
+ | ===== Warm booting ===== | ||
+ | Warm booting is done when the Bootloader client restarts the Crazyflie in bootloader more automatically. While implemented in firmware this mode is not yet implemented in the PC client. | ||
