doc:crazyflie:client:cfloader:index [2018-03-05 15:48] arnaud |
doc:crazyflie:client:cfloader:index [2019-09-05 15:25] kimberly |
+ | https:// | ||
====== Bootloader the Crazyflie 1.0/2.0 ====== | ====== Bootloader the Crazyflie 1.0/2.0 ====== | ||
The Crazyflie can be bootloaded from the commandline using the // | The Crazyflie can be bootloaded from the commandline using the // | ||
Line 15: | Line 25: | ||
CLOAD_CMDS = -w radio:// | CLOAD_CMDS = -w radio:// | ||
+ | After this, 'make cload' will restart the Crazyflie in bootlader mode, flash it and restart it with the new firmware. | ||
+ | In warmboot mode the bootloader is launched using a random address. This means that multiple Crazyflie can be programmed at the same time without collision. | ||
+ | If the flashing operation fails or if the firmware has a bug, it may be impossible to warmboot. In that case start the bootloader manually and disable warmboot temporarly by programming with: | ||
+ | make cload CLOAD_CMDS= | ||
