doc:crazyflie:client:cfloader:index [2018-03-05 15:48] arnaud |
doc:crazyflie:client:cfloader:index [2020-05-12 14:27] (current) kimberly |
| ====== Bootloader the Crazyflie 1.0/2.0 ====== | ====== Bootloader the Crazyflie 1.0/2.0 ====== | ||
| The Crazyflie can be bootloaded from the commandline using the // | The Crazyflie can be bootloaded from the commandline using the // | ||
| Line 15: | Line 20: | ||
| CLOAD_CMDS = -w radio:// | CLOAD_CMDS = -w radio:// | ||
| + | After this, 'make cload' will restart the Crazyflie in bootlader mode, flash it and restart it with the new firmware. | ||
| + | <WRAP center round info> | ||
| + | In warmboot mode the bootloader is launched using a random address. This means that multiple Crazyflie can be programmed at the same time without collision. | ||
| + | <WRAP center round important> | ||
| + | If the flashing operation fails or if the firmware has a bug, it may be impossible to warmboot. In that case start the bootloader manually and disable warmboot temporarly by programming with: | ||
| + | make cload CLOAD_CMDS= | ||
