doc:crazyflie:client:pycfclient:index [2017-03-29 13:48] tobias [Firmware upgrade] |
doc:crazyflie:client:pycfclient:index [2017-04-18 16:19] tobias [Main UI] |
Line 9: | Line 9: | ||
Line 22: | Line 20: | ||
Line 44: | Line 44: | ||
* //List of Crazyflies:// | * //List of Crazyflies:// | ||
- | * //Scan:// Re-scan for Crazyflies (not you're Crazyflie must be powered on to show up in the list) | + | * //Scan:// Re-scan for Crazyflies (note you're Crazyflie must be powered on to show up in the list) |
* //Cancel:// Go back | * //Cancel:// Go back | ||
Line 150: | Line 150: | ||
- Advanced flight control settings are available if Advanced mode has been selected (settings are in %): | - Advanced flight control settings are available if Advanced mode has been selected (settings are in %): |
