doc:crazyflie:client:pycfclient:index [2017-04-11 17:42] bjorn [Flightcontrol] |
doc:crazyflie:client:pycfclient:index [2017-04-18 16:21] tobias |
Line 9: | Line 9: | ||
Line 22: | Line 20: | ||
- | ===== Connecting ===== | ||
- | There' | ||
- | <WRAP group> | ||
- | <WRAP half column> | ||
- | * //Scan:// Re-scan for Crazyflies (note you're Crazyflie must be powered on to show up in the list) | ||
===== Firmware upgrade ===== | ===== Firmware upgrade ===== |
