doc:crazyflie:client:pycfclient:index [2017-04-11 17:42] bjorn [Flightcontrol] |
doc:crazyflie:client:pycfclient:index [2017-04-18 16:24] tobias [Firmware upgrade] |
Line 9: | Line 9: | ||
Line 22: | Line 20: | ||
- | ===== Connecting ===== | ||
- | There' | ||
- | <WRAP group> | ||
- | <WRAP half column> | ||
- | * //Scan:// Re-scan for Crazyflies (note you're Crazyflie must be powered on to show up in the list) | ||
===== Firmware upgrade ===== | ===== Firmware upgrade ===== | ||
Line 59: | Line 41: | ||
* Make sure that the Crazyflie is disconnected from the client and powered off | * Make sure that the Crazyflie is disconnected from the client and powered off | ||
* Go to the menu // | * Go to the menu // | ||
- | * For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. | + | * For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. If a wrong nRF51 firmware has been flashed you might have to start from an un-powered state. Then hold the button and connect power. |
* Click " | * Click " | ||
* For Crazyflie 1.0 now power it on **within 5 seconds** using the battery (not USB), the booloader should now connect | * For Crazyflie 1.0 now power it on **within 5 seconds** using the battery (not USB), the booloader should now connect |
