doc:crazyflie:client:pycfclient:zmq [2015-07-15 16:31] 127.0.0.1 external edit |
doc:crazyflie:client:pycfclient:zmq [2020-05-12 14:28] (current) kimberly |
The [[doc: | The [[doc: | ||
Line 88: | Line 94: | ||
| pitch | N/A | degrees | | | | pitch | N/A | degrees | | | ||
| yaw | N/A | degrees/ | | yaw | N/A | degrees/ | ||
- | | thrust | 0-60000 | 16bit PWM | | | + | | thrust | 0-100 | Percent |
| estop | T/F | boolean | Used to stop the Crazyflie and disable the control | | | estop | T/F | boolean | Used to stop the Crazyflie and disable the control | | ||
| alt1 | T/F | boolean | Alt1 is internally mapped to functionality like switching LED-ring effect | | | alt1 | T/F | boolean | Alt1 is internally mapped to functionality like switching LED-ring effect | |
