doc:crazyflie:crtp:commander [2014-11-25 15:42] macke created |
doc:crazyflie:crtp:commander [2020-05-12 14:17] kimberly |
+ | ====== Commander ====== | ||
+ | The commander port is used to send control set-points for the roll/ | ||
+ | ====== Communication protocol ====== | ||
+ | | ROLL | PITCH | YAW |THRUST | | ||
+ | Length | ||
+ | ^ Name ^ Byte ^ Size ^ Type ^ Comment ^ | ||
+ | | ROLL | 0-3 | 4 | float | The pitch set-point | | ||
+ | | PITCH | 4-7 | 4 | float | The roll set-point | | ||
+ | | YAW | 8-11 | 4 | float | The yaw set-point | | ||
+ | | THRUST | 12-13 | 2 | uint16_t | The thrust set-point | |
