doc:crazyflie:crtp:console [2014-11-25 15:39] macke created |
doc:crazyflie:crtp:console [2015-07-15 16:31] 127.0.0.1 external edit |
+ | ====== Console ====== | ||
+ | This port is used as a one-way text console for printing text from the Crazyflie to a host using the consoleprintf function. | ||
+ | ====== Communication protocol ====== | ||
+ | Answer (Crazyflie to host): | ||
+ | | PRINTED CONSOLE TEXT | | ||
+ | Length | ||
+ | The contents of the buffer on the copter side is sent if any of the following is fulfilled: | ||
+ | * The output buffer (of 31 bytes) is full | ||
+ | * A " | ||
+ | * A flush command as been issued |
