doc:crazyflie:crtp:localization [2017-02-18 12:17] arnaud [External Position] |
doc:crazyflie:crtp:localization [2020-05-12 14:21] kimberly |
====== Localization CRTP port ====== | ====== Localization CRTP port ====== | ||
Line 29: | Line 33: | ||
^ ID ^ Packet ^ | ^ ID ^ Packet ^ | ||
- | | 3 | LPP Short packet tunnel | | + | | 2 | LPP Short packet tunnel |
+ | | 3 | Enable emergency stop | | ||
+ | | 4 | Reset emergency stop timeout | ||
==== LPP Short packet tunnel ==== | ==== LPP Short packet tunnel ==== | ||
Line 35: | Line 41: | ||
Packet used to send LPP short packet to the loco positioning system. The payload is sent to the sytem as an [[doc: | Packet used to send LPP short packet to the loco positioning system. The payload is sent to the sytem as an [[doc: | ||
+ | ==== Emergency stop ==== | ||
+ | When received, the stabilizer loop is set in emergency stop mode which stops all the motors. The loop stays in emergency stop mode until the situation is reset. | ||
+ | ==== Reset emergency stop timeout ==== | ||
+ | At startup the emergency stop timeout is disabled. | ||
+ | The first time this packet is receive, the emergency stop timeout is enabled with a timeout of 1 second. | ||
+ | This packet should then be sent, and received by the Crazyflie, at least once every 1 second otherwise the stabilizer loop will be set in emergency stop and all motors will stop. | ||
