doc:crazyflie:crtp:mem [2015-09-17 12:01] arnaud [Logical flow] |
doc:crazyflie:crtp:mem [2020-05-12 14:22] kimberly |
====== Memory access ====== | ====== Memory access ====== | ||
Memory access is not used for the [[projects: | Memory access is not used for the [[projects: | ||
Line 13: | Line 19: | ||
Getting information and reading/ | Getting information and reading/ | ||
- | <code> | + | <ditaa> |
--> | Get number of memories |----->| Fetch memory info |---->| More memories? |--------> | --> | Get number of memories |----->| Fetch memory info |---->| More memories? |--------> | ||
Line 21: | Line 27: | ||
Yes | Yes | ||
- | </code> | + | </ditaa> |
====== Communication protocol ====== | ====== Communication protocol ====== | ||
The memory port uses 3 different channels: | The memory port uses 3 different channels: | ||
Line 83: | Line 89: | ||
Example of requesting the information for a 1-wire memory with MEM_ID=1, MEM_SIZE=112bytes, | Example of requesting the information for a 1-wire memory with MEM_ID=1, MEM_SIZE=112bytes, | ||
- | Host-to-Crazyflie: | + | Host-to-Crazyflie: |
Crazyflie-to-Host: | Crazyflie-to-Host: | ||
