doc:crazyflie:crtp:param [2015-11-26 21:56] arnaud [Set by name] |
doc:crazyflie:crtp:param [2020-05-12 14:22] (current) kimberly |
| ====== Parameters ====== | ====== Parameters ====== | ||
| The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters: | The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters: | ||
| Line 112: | Line 116: | ||
| | (n+1)-(n+m+1) | | (n+1)-(n+m+1) | ||
| | (n+m+2) | | (n+m+2) | ||
| - | | (n+m+3) | + | | (n+m+3) |
| - | | (n+m+4) | + | |
