User Tools
Site Tools
doc:crazyflie:crtp:param
Differences
Link to this comparison view
Next revision
Previous revision
doc:crazyflie:crtp:param [2015-07-15 16:31]
127.0.0.1 external edit
doc:crazyflie:crtp:param [2020-05-12 14:22] (current)
Line 1: Line 1:
-==== Parameters ====+<WRAP center round important 60%>
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
 +</WRAP>
 +====== Parameters ======
 The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters: The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters:
-^ Port      ^ Channel     ^ Function          ^ + Port   Channel  ^ Function          ^
-|  2        | 0           | TOC access        | +|  2             | [[doc:crazyflie:crtp:param#toc_access|TOC access]]        |
-|  2        | 1           | Parameter read    | +|  2             | [[doc:crazyflie:crtp:param#parameter_read|Parameter read]]    |
-|  2        | 2           | Parameter write   |+|  2             | [[doc:crazyflie:crtp:param#parameter_write|Parameter write]]
 +|  2      3        | [[doc:crazyflie:crtp:param#misc_command|Misc. commands]]    |
-=== TOC access (Port 2 channel 0) ===+===== TOC access =====
 These messages permit to access the parameters table of content. The first byte of the message is a message ID, three messages ID are defined: These messages permit to access the parameters table of content. The first byte of the message is a message ID, three messages ID are defined:
Line 33: Line 38:
 The CRC32 is a hash of the copter TOC. This is aimed at implementing caching of the TOC in the PC Utils to avoid fetching the full TOC each time the copter is connected. The CRC32 is a hash of the copter TOC. This is aimed at implementing caching of the TOC in the PC Utils to avoid fetching the full TOC each time the copter is connected.
-=== Parameter read (Port 2 channel 1and parameter write (Port 2 channel 2)===+The type is one byte describing the parameter type:
 +^ Type code ^ C type ^ Python unpack |
 +| 0x08      | uint8_t | '<B'
 +| 0x09      | uint16_t | '<H'
 +| 0x0A      | uint32_t | '<L'
 +| 0x0B      | uint64_t | '<Q'
 +| 0x00      | int8_t | '<b'
 +| 0x01      | int16_t | '<h'
 +| 0x02      | int32_t | '<i'
 +| 0x03      | int64_t | '<q'
 +| 0x05      | FP16 | ''
 +| 0x06      | float | '<f'
 +| 0x07      | double | '<d'
 +===== Parameter read =====
 +<WRAP group>
 +<WRAP half column>
 +^ Byte ^ Request fields ^ Content
 +|  0   | ID       | ID of the parameter to read (see TOC) |
 +</WRAP>
 +<WRAP half column>
 +^ Byte ^ Answer fields  ^ Content
 +|  0   | ID       | ID of the parameter |
 +|  1-..  | value | Value of the parameter. Size and format is described in the TOC |
 +</WRAP>
 +</WRAP>
 +The read request is a simple packet on channel 1. Crazyflie answers with the value.
 +===== Parameter write =====
 +<WRAP group>
 +<WRAP half column>
 +|  0   | ID       | ID of the parameter to write |
 +|  1-...   | value | Value to write. Size and format is described in the TOC |
 +</WRAP>
 +<WRAP half column>
 +|  1-...  | value | Value of the parameter. Size and format is described in the TOC |
 +</WRAP>
 +</WRAP>
 +The write request is a simple packet on channel 2. Crazyflie sends back the parameter value as an acknowledgement.
 +===== Misc. commands =====
 +The following misc commands are implemented:
 +^  Code  ^ Command ^
 +|  0x00  | [[doc:crazyflie:crtp:param#set_by_name|Set by name]] |
 +==== Set by name ====
 +<WRAP group>
 +<WRAP half column>
 +|  0   | SET_BY_NAME       | 0x00 |
 +|  1-n   | group | Name of the group |
 +|  n-(n+1)  | NULL | 0 |
 +|  (n+1)-(n+m+1)   | name | Name of the parameter |
 +|  (n+m+1)-(n+m+2)  | NULL | 0 |
 +|  (n+m+2)-(n+m+3)  | TYPE | Parameter type |
 +|  (n+m+3)-...      | value | Value. Size and format is described by type |
 +</WRAP>
 +<WRAP half column>
 +|  (n+m+2)  | NULL | 0 |
 +|  (n+m+3)  | ERROR | 0 if the parameter has been successfully written. Other code are taken from[[http://www.virtsync.com/c-error-codes-include-errno|errno C codes]]. |
 +</WRAP>
 +</WRAP>
-The following messages are sent from the client to the Crazyflie: +//Group// and //name// are ascii strings of size respectively //n// and //m//The type corresponds to the TOC type of the parameter. It is checked for consistency.
-^  **Request for**    **Byte**  ^  **Description** +
-|  Parameter read    |          | The id of the parameter to read   | +
-|  Parameter write            | The id of the parameter to write   | +
-|   :::              |          | The value to set |+
-The following messages are sent from the Crazyflie to the client: +This command is useful to set a parameter without having to fetch the full TOC. It is enough to know the group, name and type of the parameter to write it.
-^  **Reply for**            ^  **Byte**  ^  **Description** +
-|  Parameter read & write   |          | Parameter id      | +
-|   :::                         1-n    | Parameter value   |+
doc/crazyflie/crtp/param.1436970670.txt.gz · Last modified: 2015-10-26 18:24 (external edit)
