User Tools
Site Tools
doc:crazyflie:crtp:param
Differences
Link to this comparison view
Next revision
Previous revision
doc:crazyflie:crtp:param [2015-11-26 21:56]
arnaud [Set by name]
doc:crazyflie:crtp:param [2020-05-12 14:22] (current)
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
 +</WRAP>
 ====== Parameters ====== ====== Parameters ======
 The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters: The parameters system makes all the gettable and settable parameters of the copter accessible. The copter holds a table of parameters which can be retrieved. In this table every parameter name is associated with an ID and a group name. Three IDs are used to acces the TOC and the parameters:
Line 112: Line 116:
 |  (n+1)-(n+m+1)   | name | Name of the parameter | |  (n+1)-(n+m+1)   | name | Name of the parameter |
 |  (n+m+2)  | NULL | 0 | |  (n+m+2)  | NULL | 0 |
-|  (n+m+3) TYPE Parameter type | +|  (n+m+3) ERROR 0 if the parameter has been successfully written. Other code are taken from[[http://www.virtsync.com/c-error-codes-include-errno|errno C codes]]. |
-|  (n+m+4)  | TYPE | Error |+
 </WRAP> </WRAP>
 </WRAP> </WRAP>
doc/crazyflie/crtp/param.1448571395.txt.gz · Last modified: 2015-11-26 21:56 by arnaud
