Next revision | Previous revision Last revision Both sides next revision | ||
doc:crazyflie:dev:arch:communication [2015-03-03 16:23] macke created |
doc:crazyflie:dev:arch:communication [2017-06-21 15:38] arnaud [Module] |
+ | ====== Communication stack ====== | ||
+ | The Crazyflie communication stack is divided into three layers: | ||
+ | * **Module**: End receiving service of data | ||
+ | * **CRTP**: Protocol for communication | ||
+ | * **Link**: Physical communication link | ||
+ | Each layer communicates on a logical level with the same layer on the other side. | ||
+ | ===== Module ===== | ||
+ | Each module is assigned a port, which works much like the ports in UDP. Sending data on a specific port will make sure it's routed to the registered module for this port. The data that is sent to/from a specific port also contains a channel id of 3 bits. This channel id can be used to more easily route the data once inside the module. | ||
+ | ===== CRTP ===== | ||
+ | The protocol used for sending data to/from the Crazyflie is named CRTP (Crazyflie RealTime Protocol). In it's current state the protocol isn't real-time, but there' | ||
+ | Each CRTP packet is 32 bytes, of which 1 byte is taken by the header. This gives a total payload of 31 bytes per packet. The header holds the port (8 bits), channel (2 bits) and reserved (2 bits). | ||
+ | ===== Link ===== | ||
+ | The link is responsible for transferring the packet to/from the Crazyflie. Currently there' | ||
+ | Since no CRC/ | ||
+ | ====== Architecture ====== | ||
+ | ===== Modules ===== | ||
+ | In the firmware most modules (that are connected to ports) are implemented as tasks. Each task is blocking on a message delivery queue where incoming CRTP packets are delivered. At start up each of these tasks (and other modules) register a callback with the communication layer for their pre-defined ports. | ||
+ | For every module that is used to send/ |
