doc:crazyflie:dev:env:android [2015-01-29 11:51] macke |
doc:crazyflie:dev:env:android [2021-06-24 16:59] kimberly |
+ | ====== Setting up an development environment for the Crazyflie Android client ====== | ||
+ | This guide will help you getting started with setting up a development environment for the Crazyflie Android client, running the app from source code and contributing code. | ||
+ | ===== Installation ===== | ||
+ | ==== Requirements ==== | ||
+ | * An Android device running version 4.0 or higher (the code might be changed to run on lower versions, but this has not been tested yet) | ||
+ | * USB On-the-go (OTG) cable (aka. USB Host cable) to connect the Android device to the Crazyradio dongle | ||
+ | ==== Installing the Android Development Tools (ADT) ==== | ||
+ | - Download the most recent Android Development Tools from http:// | ||
+ | * get the latest ADT Bundle (eg. adt-bundle-windows-x86-20130917.zip for Win32) | ||
+ | - Extract the zip file and start Eclipse (adt-bundle-windows-x86-20130917/ | ||
+ | - Start the Android SDK Manager (Window -> Android SDK Manager) | ||
+ | * select Android 4.0 (API 14) and install all of its components | ||
+ | * using an actual Android device for development is recommended | ||
+ | * If you still want to use the emulator for development on a Windows machine, then you should use the "Intel x86 Atom System Image" | ||
+ | If you have problems installing the ADT environment or setting up the emulator you might find some help here: | ||
+ | * http:// | ||
+ | * http:// | ||
+ | * http:// | ||
+ | * http:// | ||
+ | ==== Getting the Crazyflie Android client source code ==== | ||
+ | - Install a Git client for your operating system | ||
+ | * Windows client from http:// | ||
+ | * Linux client, e.g. on Debian based systems with "sudo apt-get install git" | ||
+ | - The Eclipse Git plug-in (EGit) is already included in your ADT environment, | ||
+ | * Use the Update manager (Help -> Install new software...) | ||
+ | * Update site: http:// | ||
+ | - With the EGit plug-in you can checkout the Crazyflie Android client source code from https:// | ||
+ | * or on the commandline: | ||
+ | ==== Running the Android client from source code ==== | ||
+ | - On Windows: install USB drivers for your Android device (http:// | ||
+ | - Enable USB debugging on your Android device (Settings > Developer options) | ||
+ | * You might need to enable the developer options first! | ||
+ | - Connect your PC to the Android device via USB or Wifi | ||
+ | - "Run as Android application" | ||
+ | - Use a USB On-the-go (OTG) cable (aka. USB Host cable) to connect your Android device to the Crazyradio dongle | ||
+ | - Run the Crazyflie app (see also [[doc: | ||
+ | More info about USB drivers, developer options and debugging setup can be found here: | ||
+ | * http:// | ||
+ | ===== Reporting bugs or requesting features ==== | ||
+ | Bugs and feature requests should be added as GitHub issues: https:// | ||
+ | ===== Contributing your code ==== | ||
+ | If you consider contributing code, then you should create a [[https:// | ||
+ | ==== Coding standard ==== | ||
+ | Due to a lack of time and laziness the code is still messy, but in general the coding style should follow the [[http:// | ||
+ | * [[http:// | ||
