User Tools
Site Tools
doc:crazyflie:dev:env:windows
Differences
Link to this comparison view
doc:crazyflie:dev:env:windows [2018-07-07 12:58]
theseankelly [ARM Toolchain]
doc:crazyflie:dev:env:windows [2021-06-24 16:54] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Windows Development Environment ====== ====== Windows Development Environment ======
 This tutorial will demonstrate how to set up a windows machine to develop, build, and deploy binaries for the crazyflie natively, without use of a VM. Some notes on the setup environment used to write this guide: This tutorial will demonstrate how to set up a windows machine to develop, build, and deploy binaries for the crazyflie natively, without use of a VM. Some notes on the setup environment used to write this guide:
doc/crazyflie/dev/env/windows.txt · Last modified: 2021-06-24 16:54 by kimberly
