doc:crazyflie:dev:firmware:deck_memory_format [2015-08-06 12:11] arnaud [Header] |
doc:crazyflie:dev:firmware:deck_memory_format [2020-05-12 14:22] (current) kimberly |
====== Deck memory format ====== | ====== Deck memory format ====== | ||
Line 30: | Line 34: | ||
The header allows to detect the deck installed and to verify that the deck stack is compatible. | The header allows to detect the deck installed and to verify that the deck stack is compatible. | ||
- | The // | + | The // |
^ Drive ^ PC11 ^ PC10 ^ PB7 ^ PB6 ^ PB8 ^ PB5 ^ PB4 ^ PC12 ^ PA2 ^ PA3 ^ PA5 ^ PA6 ^ PA7 ^ P0.11 ^ P0.12 ^ P0.08 ^ | ^ Drive ^ PC11 ^ PC10 ^ PB7 ^ PB6 ^ PB8 ^ PB5 ^ PB4 ^ PC12 ^ PA2 ^ PA3 ^ PA5 ^ PA6 ^ PA7 ^ P0.11 ^ P0.12 ^ P0.08 ^ |
