doc:crazyflie:index [2015-08-27 14:15] arnaud [Crazyflie side] |
doc:crazyflie:index [2016-03-29 16:33] bjorn [Guides] |
Line 15: | Line 15: | ||
Aside from stand-alone clients there' | Aside from stand-alone clients there' | ||
* [[doc: | * [[doc: | ||
- | * [[doc: | ||
- | ====== Hosts ====== | ||
- | The client and APIs can be used on a number of different host OSes, below are the links to the different guides on how to get going. Note, that if you want to set up the development environment then have a look below. | ||
- | * [[doc: | ||
- | * [[doc: | ||
- | * [[doc: | ||
- | * [[doc: | ||
- | ====== Guides ====== | + | |
- | * [[doc: | + | |
Line 34: | Line 25: | ||
- | * [[doc: | + | * [[doc: |
===== Architecture ===== | ===== Architecture ===== | ||
Line 41: | Line 32: | ||
==== System ==== | ==== System ==== | ||
Some parts of the design span multiple firmwares and doesn' | Some parts of the design span multiple firmwares and doesn' | ||
Line 52: | Line 43: | ||
