User Tools
Site Tools
doc:crazyflie:index
Differences
Link to this comparison view
Next revision
Previous revision
doc:crazyflie:index [2015-08-06 12:11]
arnaud Typo
doc:crazyflie:index [2020-05-12 14:55]
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]] or
 +[[https://www.bitcraze.io/documentation/repository/]]
 +</WRAP>
 ====== Crazyflie ====== ====== Crazyflie ======
 The documentation found here is generic and valid for all Crazyflie/Crazyradio versions. If you are looking for details on a specific product then have a look at the [[projects:index|projects]] page for links. The documentation found here is generic and valid for all Crazyflie/Crazyradio versions. If you are looking for details on a specific product then have a look at the [[projects:index|projects]] page for links.
Line 15: Line 21:
 Aside from stand-alone clients there's also sets of applications and scripts that works together for using the Crazyflie. Aside from stand-alone clients there's also sets of applications and scripts that works together for using the Crazyflie.
   * [[doc:crazyflie:vision:index|Vision and control]]: Collection of scripts and applications for using the Crazyflie with camera/Kinect for host   * [[doc:crazyflie:vision:index|Vision and control]]: Collection of scripts and applications for using the Crazyflie with camera/Kinect for host
-  * [[doc:crazyflie:ros:index|ROS]]: Using the Crazyflie with ROS
-====== Hosts ======
-The client and APIs can be used on a number of different host OSes, below are the links to the different guides on how to get going. Note, that if you want to set up the development environment then have a look below.
-  * [[doc:crazyflie:host:linux:index|Linux]]: Setting up and using the client on Linux
-  * [[doc:crazyflie:host:win:index|Windows XP/Vista/7/8]]: Setting up and using the client on Linux
-  * [[doc:crazyflie:host:mac:index|Mac OSX]]: Setting up and using the client on Linux
-  * [[doc:crazyflie:hist:pi:index|Raspberry Pi]]: How to setup and configure our Raspberry Pi image for flying
-====== Guides ======  +
-  * [[doc:crazyflie:guides:flying|How to get flying]]: Basic information on how to fly the Crazyflie +
-  * [[doc:crazyflie:guides:ledring|LED-ring]]: How to experiment and play with the Crazyflie 2.0 LED-ring+
 ====== Development ====== ====== Development ======
 ===== Getting started ===== ===== Getting started =====
 For getting started with development and setting up the environment have a look at the following topics: For getting started with development and setting up the environment have a look at the following topics:
-  * [[doc:crazyflie:dev:env:firmware|Firmware development environment]]: How to set up the firmware development environment
   * [[doc:crazyflie:dev:env:python|Python client/API development environment]]: How to set up the Python client/API development environment   * [[doc:crazyflie:dev:env:python|Python client/API development environment]]: How to set up the Python client/API development environment
   * [[doc:crazyflie:dev:starting|Getting started]]: A quick overview of how to use the logging/parameter frameworks and building/flashing from the VM   * [[doc:crazyflie:dev:starting|Getting started]]: A quick overview of how to use the logging/parameter frameworks and building/flashing from the VM
-  * [[doc:crazyflie:dev:env:android|Andoid development environment]]: How to set up the Android development environment development environment +  * [[doc:crazyflie:dev:env:android|Android development environment]]: How to set up the Android development environment development environment
 +  * [[doc:crazyflie:dev:env:matlab|Using Matlab with the Crazyflie API]]: How to use Matlab from python together with the Crazyflie API
 +  * [[doc:crazyflie:dev:env:windows|Windows development environment]]: How to set up a development environment on Windows (no VM)
 ===== Architecture ===== ===== Architecture =====
 The architecture part of the documentation details things that are not User guide or API. It's information that's useful to have to understand how the system and it's parts fit together. The architecture part of the documentation details things that are not User guide or API. It's information that's useful to have to understand how the system and it's parts fit together.
Line 41: Line 38:
 ==== System ==== ==== System ====
 Some parts of the design span multiple firmwares and doesn't below to any one part of the system. Here's a more generic overview of these designs and below there's more detailed information about the specific parts that build them up. Some parts of the design span multiple firmwares and doesn't below to any one part of the system. Here's a more generic overview of these designs and below there's more detailed information about the specific parts that build them up.
-  * [[doc:crazyflie:dev:arch:logparam|Logging and parameters]]: The design of the logging and parameter framwork+  * [[doc:crazyflie:dev:arch:logparam|Logging and parameters]]: The design of the logging and parameter framework
   * [[doc:crazyflie:dev:arch:communication|Communication]]: Generic information about how communication works on a higher level   * [[doc:crazyflie:dev:arch:communication|Communication]]: Generic information about how communication works on a higher level
Line 52: Line 49:
   * [[doc:crazyflie:dev:fimware:index|Highlevel architecture]]: The highlevel architecture of the firmware   * [[doc:crazyflie:dev:fimware:index|Highlevel architecture]]: The highlevel architecture of the firmware
   * [[doc:crazyflie:dev:fimware:communication|Radio communication and ports]]: How communication is structured and how ports are used   * [[doc:crazyflie:dev:fimware:communication|Radio communication and ports]]: How communication is structured and how ports are used
-  * [[doc:crazyflie:dev:fimware:sensor_to_control|From sensors to PWM]]: Highlevel details on how the sensors are aquired, the sensor fusion, PID and PWM output+  * [[doc:crazyflie:dev:fimware:sensor_to_control|From sensors to PWM]]: Highlevel details on how the sensors are acquired, the sensor fusion, PID and PWM output
   * [[doc:crazyflie:dev:firmware:deck_memory_format|Deck memory format]]: Deck 1-wire memory format documentation   * [[doc:crazyflie:dev:firmware:deck_memory_format|Deck memory format]]: Deck 1-wire memory format documentation
 +  * [[doc:crazyflie:api:firmware:deck|Deck API]]: API to develop Deck drivers
 ===== APIs ===== ===== APIs =====
 For communicating with the Crazyflie there's a number of APIs available, here's a list: For communicating with the Crazyflie there's a number of APIs available, here's a list:
doc/crazyflie/index.txt · Last modified: 2020-05-12 14:55 by kimberly
