User Tools
Site Tools
doc:crazyflie:index
Differences
Link to this comparison view
Next revision
Previous revision
doc:crazyflie:index [2016-03-29 16:28]
bjorn [Getting started]
doc:crazyflie:index [2020-05-12 14:55]
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]] or
 +[[https://www.bitcraze.io/documentation/repository/]]
 +</WRAP>
 ====== Crazyflie ====== ====== Crazyflie ======
 The documentation found here is generic and valid for all Crazyflie/Crazyradio versions. If you are looking for details on a specific product then have a look at the [[projects:index|projects]] page for links. The documentation found here is generic and valid for all Crazyflie/Crazyradio versions. If you are looking for details on a specific product then have a look at the [[projects:index|projects]] page for links.
Line 20: Line 26:
 ====== Development ====== ====== Development ======
-10===== Getting started =====+===== Getting started =====
 For getting started with development and setting up the environment have a look at the following topics: For getting started with development and setting up the environment have a look at the following topics:
   * [[doc:crazyflie:dev:env:python|Python client/API development environment]]: How to set up the Python client/API development environment   * [[doc:crazyflie:dev:env:python|Python client/API development environment]]: How to set up the Python client/API development environment
   * [[doc:crazyflie:dev:starting|Getting started]]: A quick overview of how to use the logging/parameter frameworks and building/flashing from the VM   * [[doc:crazyflie:dev:starting|Getting started]]: A quick overview of how to use the logging/parameter frameworks and building/flashing from the VM
   * [[doc:crazyflie:dev:env:android|Android development environment]]: How to set up the Android development environment development environment   * [[doc:crazyflie:dev:env:android|Android development environment]]: How to set up the Android development environment development environment
 +  * [[doc:crazyflie:dev:env:matlab|Using Matlab with the Crazyflie API]]: How to use Matlab from python together with the Crazyflie API
 +  * [[doc:crazyflie:dev:env:windows|Windows development environment]]: How to set up a development environment on Windows (no VM)
 ===== Architecture ===== ===== Architecture =====
 The architecture part of the documentation details things that are not User guide or API. It's information that's useful to have to understand how the system and it's parts fit together. The architecture part of the documentation details things that are not User guide or API. It's information that's useful to have to understand how the system and it's parts fit together.
doc/crazyflie/index.txt · Last modified: 2020-05-12 14:55 by kimberly
