doc:crazyflie:vision:setup [2015-05-25 15:01] arnaud created |
doc:crazyflie:vision:setup [2021-06-24 16:43] (current) kimberly |
| + | ====== Crazyflie vision system setup ====== | ||
| + | As explained in the vision [[doc: | ||
| + | This page aims at explaining step-by-step how to get everything working. It is based on the Windows Kinect SDK implementation of the detector using the setup Bitcraze had at the Maker Faire Bay Area 2015. | ||
| + | ===== Hardware requirement ===== | ||
| + | The system requires: | ||
| + | * One Kinect 2 for windows sensor | ||
| + | * One PC running Windows 8.1+, [[https:// | ||
| + | * One PC running Linux, preferably Ubuntu 14.04+ | ||
| + | * The two PC should be connected using low latency links like an Ethernet network cable. | ||
| + | The reason for having 2 PCs is that the controller and the clients are not working properly on Windows yet and the Vision algorithm requires functionalities that are not available in the Kinect Linux driver yet (the depth to 3D coordinate conversion). | ||
| + | ===== Hardware setup ===== | ||
| + | The Kinect 2 should be placed on the ground, facing up, in the middle of the room (or at least pretty far from the walls). Avoid having reflective things on the ceiling. | ||
| + | The Crazyflie shall be equiped with markers to be detected by the detection program. We put a " | ||
| + | For the markers we use a retro-reflective sticky sheet that is supposed to be stuck on fabric (it was fount at [[http:// | ||
| + | ===== Software setup ===== | ||
| + | We will assume the Linux PC has the ip 192.0.0.1 and the Windows PC the IP 192.168.0.2. | ||
| + | ==== Image Processing ==== | ||
| + | The image processing runs in the Windows computer. | ||
| + | First of all you should be able to open and compile the [[http:// | ||
| + | Then you can clone the [[https:// | ||
| + | Install all dependencies listed in the [[https:// | ||
| + | The vision detector will listen on port 1213, make sure to setup the Windows firewall accordingly when the program starts. | ||
| + | You have to stop the program from Visual studio, closing the detector windows currently does nothing. | ||
| + | When working you should see these and the crazyflie can be detected: | ||
| + | ==== Control, Set-poins and Visualizer ==== | ||
| + | These scripts runs in the Linux computer. To start, clone the [[https:// | ||
| + | The controller is client to all other parts of the system. You can check the IP in the [[https:// | ||
| + | * **client_conn** Connection to the Crazyflie client, 127.0.0.1 in our setup | ||
| + | * **kinect_conn** Connection to the Kinect detector, 192.168.0.2 in our setup | ||
| + | * **midi_conn** Connection to a midi-to-zmq server, this is not used anymore and can be ignored. | ||
| + | * **ctrl_conn** Connection to the setpoint GUI, 127.0.0.1 in our setup. | ||
| + | Once the IPs are well configured the controller, set-pint GUI and visualizer can be launched. Only the controller is required to fly, the other can optionally be launched as well. | ||
| + | ==== Client ==== | ||
| + | The client runs in the Linux computer. | ||
| + | <WRAP center round info> | ||
| + | Currently in order for scaling/ | ||
| + | * Check out the //develop// branch of the [[https:// | ||
| + | * Enable the MUX in the [[doc: | ||
| + | * Start the client, switch the input device you would like to use and set-up select the correct mapping (this needs to have //Alt 1// set up) | ||
| + | * Select the ZMQ input driver | ||
| + | * Restart the client | ||
| + | * Select the //Vision MUX// in //Input devices -> Mux// (lots of warnings in the console after this...) | ||
| + | * First select the manual input-device | ||
| + | * Deselect/ | ||
| + | * You're now ready to go. Press and hold //Alt 1// to manually control roll/ | ||
| + | ===== Working on the system ===== | ||
| + | When everything is setup you can just fly in the picture by keeping the //Alt 1// button pressed and release it to let the kinect take control. The setpoint GUI permits to change the setpoints and to control some pre-programmed patterns. | ||
| + | One of advantage of using ZMQ is that we can stop and restart parts of the system without restarting everything. If going fast it is even possible to restart the controller while the Crazyflie is flying. | ||
