doc:crazyradio:install_win7 [2013-04-30 08:25] arnaud [Install crazyradio driver on Windows 7] |
doc:crazyradio:install_win7 [2021-06-24 16:55] kimberly |
====== Install crazyradio driver on Windows 7 ====== | ====== Install crazyradio driver on Windows 7 ====== | ||
- | On Windows 7 the installation of the Crazyradio dongle will fail by default and then you will have to install the driver manually. This page documents the procedure | + | Zadig is now used to install the Crazyradio driver on Windows 7. Go to the [[doc:crazyradio:install_windows_zadig|Crazyradio manual windows installation using zadig]] page for installation |
- | ===== Procedure ===== | + | |
- | When connected, the Crazyradio dongle fails to be installed automatically by Windows | + | |
- | When that happen, open the device manager, find the uninstal USB device and right click on it to update the driver | + | |
- | In the window popping-up chose " | + | |
- | Click next, accept | + | |
