doc:crazyradio:usb:index [2012-04-02 09:07] arnaud [Dongle configuration] |
doc:crazyradio:usb:index [2012-05-11 07:36] arnaud |
- | This page document the protocol used in the version 0.33 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible. | + | This page document the protocol used in the version 0.40 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible. |
- | The USB devices have the VID/PID couple 0x1915/ | + | The USB devices have the VID/PID couple 0x1915/ |
- | | EP1 | Bulk | Data endpoint. Used to send and receive radio packets | | + | | EP1IN/ |
==== Dongle configuration ==== | ==== Dongle configuration ==== | ||
- | The following | + | Crazyradio |
- | ^ Control message | + | ^ bmRequestType ^ bRequest |
- | | SET_RADIO_CHANNEL | + | | |
- | | SET_RADIO_ADDRESS | + | | |
- | | SET_DATA_RATE | + | | 0x40 | SET_DATA_RATE |
- | | LAUNCH_BOOTLOADER | + | | 0x40 | SET_RADIO_POWER (0x04) |
+ | === Set radio channel === | ||
+ | The nrf24L chips provides 126 Channels of 1MHz from 2400MHz | ||
+ | The radio channel is set as soon as the setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. | ||
+ | === Set radio address === | ||
+ | === Set datarate === | ||
Possible values for the datarate: | Possible values for the datarate: | ||
Line 27: | Line 50: | ||
| 1 | 1MBps | | | 1 | 1MBps | | ||
| 2 | 2Mbps (Default)| | | 2 | 2Mbps (Default)| | ||
+ | === Set radio power === | ||
+ | === Configure auto retry (ARD/ARC) === | ||
+ | === Continuous carrier mode === | ||
+ | === Launch bootloader === | ||
Line 48: | Line 82: | ||
This protocol permits to transfer about 500 packets per seconds. | This protocol permits to transfer about 500 packets per seconds. | ||
===== Radio protocol ===== | ===== Radio protocol ===== | ||
