doc:crazyradio:usb:index [2012-05-14 07:50] arnaud [Dongle configuration] |
doc:crazyradio:usb:index [2012-05-17 14:14] arnaud |
Line 12: | Line 12: | ||
| EP1IN/OUT | Bulk | Data endpoints. Used to send and receive radio packets | | | EP1IN/OUT | Bulk | Data endpoints. Used to send and receive radio packets | | ||
- | ==== Dongle configuration ==== | + | ==== Data transfer ==== |
+ | The radio dongle being configured in PTX (emmiter) mode it sends packet to the copter and waits for the acknowledge. The acknowledge can contains a Payload which is the mean to receive data. If the auto acknowledge is disable there is no IN transaction. | ||
+ | To send a packet the following sequence must be followes: | ||
+ | * Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes | ||
+ | * Read the ACK from EP1_IN. The first by is the transfers status and the following bytes are the content of the ACK payload, if any. | ||
+ | To EP1_OUT: | ||
+ | From EP1_IN: | ||
+ | ^ Status | ||
+ | | 4..7 | Number of retransmition | | ||
+ | | 2..3 | Reserved | ||
+ | | 1 | Power detector | ||
+ | | 0 | Ack received | ||
Line 23: | Line 52: | ||
| 0x40 | SET_RADIO_ARD (0x05) | | 0x40 | SET_RADIO_ARD (0x05) | ||
- | === Set radio channel === | + | ==== Set radio channel |
Line 35: | Line 65: | ||
The radio channel is set as soon as the setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2. | The radio channel is set as soon as the setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2. | ||
- | === Set radio address === | + | ==== Set radio address |
Line 52: | Line 82: | ||
The default address is 0xE7E7E7E7E7. | The default address is 0xE7E7E7E7E7. | ||
- | === Set datarate === | + | ==== Set datarate |
Line 64: | Line 94: | ||
- | === Set radio power === | + | ==== Set radio power ==== |
- | === Configure auto retry (ARD/ARC) === | + | ^ bmRequestType ^ bRequest |
+ | | 0x40 | SET_RADIO_POWER | ||
- | === Continuous carrier mode === | ||
- | === Launch bootloader | + | ==== Configure auto retry (ARD/ARC) ==== |
- | ==== Data transfer | + | After sending a packet the radio automatically waits for an acknowledge. ARD and ARC permits to configure the delay the radio waits for the acknowledge and the number of time the transfer |
- | The radio dongle is configured in PTX mode (in the Nordic terminology) which means that it sends packet to the copter | + | The delay ARD depends of the length, |
- | The packet is to send is sent to the EP1 and the ack status is then received from the EP1. There are no buffering in the radio dongle, the ACK must be received by the PC before the next packet can be sent. | + | Possible values for ARD: |
- | < | + | ^ Value ^ ARD wait time ^ |
- | 1..32Bytes | + | | 0x00 | 250us | |
- | To EP1_OUT: | + | | 0x0F | 4000us |
- | 1..32 Bytes | + | |
- | 1Byte < | + | |
- | From EP1_IN: | + | |
- | This protocol permits to transfer about 500 packets per seconds. | + | ^ Value ^ Ack payload length ^ |
- | ===== Radio protocol ===== | + | | 0x80 | 0Byte | |
+ | | 0x81 | 1Byte | | ||
+ | | 0xA0 | 32Bytes | ||
+ | ARC configures the number of time the radio will retry a transfer if the Ack has not been received, it can be set from 0 to 15. | ||
+ | By default Crazyradio is configured with auto ack enable. It means that after transmiting a packet the radio waits for an acknoledge from the receiver. This setting permits to deactivate waiting for the Ack packet so that the packet will be sent only one time and there are no guarantee that it has been correctly received. | ||
+ | | Not 0 | Auto ack enable (default) | | ||
+ | The nRF24L radio chip provides a test mode in which a continous non-modulated sine wave is emited. This permits, among other things, to test the quality of the RF elements of the board. When this mode is activated the radio dongle does not transmit any packets. | ||
+ | ===== Radio protocol ===== |
