doc:crazyradio:usb:index [2012-05-17 13:53] arnaud |
doc:crazyradio:usb:index [2015-03-01 23:05] fred |
- | ====== Usb and Radio protocol of the Crazyradio dongle ====== | ||
- | The Crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. The radio communication is done using the Nordic " | ||
- | This page document the protocol used in the version 0.40 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible. | ||
- | ===== USB protocol ===== | ||
- | The USB devices have the VID/PID couple 0x1915/ | ||
- | | EP0 | Control | Control endpoint. Used to configure the dongle | | ||
- | | EP1IN/OUT | Bulk | Data endpoints. Used to send and receive radio packets | | ||
- | ==== Dongle configuration ==== | ||
- | Crazyradio vendor requests summary: | ||
- | ^ bmRequestType ^ bRequest | ||
- | | 0x40 | SET_RADIO_CHANNEL (0x01) | channel | ||
- | | 0x40 | SET_RADIO_ADDRESS (0x02) | Zero | Zero | 5 | Address | | ||
- | | 0x40 | SET_DATA_RATE (0x03) | ||
- | | 0x40 | SET_RADIO_POWER (0x04) | ||
- | | 0x40 | SET_RADIO_ARD (0x05) | ||
- | | 0x40 | SET_RADIO_ARC (0x06) | ||
- | | 0x40 | ACK_ENABLE (0x10) | ||
- | | 0x40 | SET_CONT_CARRIER (0x20) | ||
- | | 0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero | Zero | Zero | None | | ||
- | === Set radio channel === | ||
- | The nrf24L chips provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if not the command will be ignored). | ||
- | The radio channel is set as soon as the setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2. | ||
- | === Set radio address === | ||
- | The packet sent by the radio contains a 5 bytes address. The same address must be configured in the receiver for the communication to work. | ||
- | The address must follow the requirement of the section 6.4.3.2 of the nRF24LU1 documentation: | ||
- | Addresses where the level shifts only one time (that is, 000FFFFFFF) can often be detected in | ||
- | noise and can give a false detection, which may give a raised Packet-Error-Rate. Addresses | ||
- | as a continuation of the preamble (hi-low toggling) raises the Packet-Error-Rate. | ||
- | The default address is 0xE7E7E7E7E7. | ||
- | === Set datarate === | ||
- | Possible values for the datarate: | ||
- | ^ Value ^ Radio datarate ^ | ||
- | | 0 | 250Kbps | ||
- | | 1 | 1MBps | | ||
- | | 2 | 2Mbps (Default)| | ||
- | === Set radio power === | ||
- | === Configure auto retry (ARD/ARC) === | ||
- | After sending a packet the radio automatically waits for an acknowledge. ARD and ARC permits to configure the delay the radio waits for the acknowledge and the number of time the transfer will be retried in case the acknowledge is not received in that delay. | ||
- | The delay ARD depends of the length, in second, of the ack packed. This depends of the datarate and the Payload length contained in the Ack packet. The ARD can be configured either by step of 250us or by ack payload length. If the ack payload length is configured the time will be recalculated automatically even if the datarate is changed. To set the Ack payload lenght the bit 7 of Ard must be set (length | 0x80) | ||
- | Possible values for ARD: | ||
- | ^ Value ^ ARD wait time ^ | ||
- | | 0x00 | 250us | | ||
- | | 0x01 | 500us | | ||
- | | 0x0F | 4000us | ||
- | ^ Value ^ Ack payload length ^ | ||
- | | 0x80 | 0Byte | | ||
- | | 0x81 | 1Byte | | ||
- | | 0xA0 | 32Bytes | ||
- | ARC configures the number of time the radio will retry a transfer if the Ack has not been received, it can be set from 0 to 15. | ||
- | By default ARD=32Bytes (0xA0) and ARC=3. | ||
- | === Continuous carrier mode === | ||
- | By default Crazyradio is configured with auto ack enable. It means that after transmiting a packet the radio waits for an acknoledge from the receiver. This setting permits to deactivate waiting for the Ack packet so that the packet will be sent only one time and there are no guarantee that it has been correctly received. | ||
- | ^ Active values ^ Meaning | ||
- | | 0 | Auto ack deactivated | ||
- | | Not 0 | Auto ack enable (default) | | ||
- | The nRF24L radio chip provides a test mode in which a continous non-modulated sine wave is emited. This permits, among other things, to test the quality of the RF elements of the board. When this mode is activated the radio dongle does not transmit any packets. | ||
- | while the continuous carrier mode is active it is possible to set channel and power to change the frequency and power of the emitted wave. | ||
- | | 0 | Dongle working normally (default) | | ||
- | | Not 0 | Dongle in continuous carrier mode | | ||
- | === Launch bootloader === | ||
- | This command is used to launch the Nordic semiconductor USB bootloader. After sending this command a USB reset shall be emitted which will trigger the dongle to start the bootloader. After sending this command the Dongle is only waiting for a USB reset which means that any other commands or data will be ignored. | ||
- | The bootloader is pre-loaded by Nordic Semi. in the nRF24LU1 chip at the address 0x7800. The Crazyradio firmware will jump to it when the sequence LAUCH_BOOTLOADER following by a USB reset is executed. The bootloader will appear at VID/PID of 0x1915/ | ||
- | A PC client for the bootloader is part of the Crazyflie ground station program. | ||
- | ==== Data transfer ==== | ||
- | The radio dongle is configured in PTX mode (in the Nordic terminology) which means that it sends packet to the copter and waits for the acknowledge. The acknowledge can contains a Payload which is the mean to get data from the copter. | ||
- | The packet is to send is sent to the EP1 and the ack status is then received from the EP1. There are no buffering in the radio dongle, the ACK must be received by the PC before the next packet can be sent. | ||
- | To EP1_OUT: | ||
- | 1..32 Bytes | ||
- | 1Byte < | ||
- | From EP1_IN: | ||
- | This protocol permits to transfer about 500 packets per seconds. | ||
- | ===== Radio protocol ===== | ||
