doc:crazyradio:usb:index [2012-05-17 14:14] arnaud |
doc:crazyradio:usb:index [2013-01-05 23:43] arnaud [Continuous carrier mode] |
Line 18: | Line 18: | ||
To send a packet the following sequence must be followes: | To send a packet the following sequence must be followes: | ||
* Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes | * Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes | ||
- | * Read the ACK from EP1_IN. The first by is the transfers status and the following bytes are the content of the ACK payload, if any. | + | * Read the ACK from EP1_IN. The first byte is the transfers status and the following bytes are the content of the ACK payload, if any. |
Line 41: | Line 41: | ||
| 0 | Ack received | | 0 | Ack received | ||
- | ==== Dongle configuration | + | ==== Dongle configuration |
Line 54: | Line 54: | ||
| 0x40 | ACK_ENABLE (0x10) | | 0x40 | ACK_ENABLE (0x10) | ||
+ | | 0x40 | SCAN_CHANNELS (0x21) | ||
+ | | 0xC0 | SCAN_CHANNELS (0x21) | ||
Line 63: | Line 65: | ||
The nrf24L chips provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if not the command will be ignored). | The nrf24L chips provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if not the command will be ignored). | ||
- | The radio channel is set as soon as the setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2. | + | The radio channel is set as soon as the USB setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2. |
==== Set radio address ==== | ==== Set radio address ==== | ||
Line 99: | Line 101: | ||
| 0x40 | SET_RADIO_POWER (0x04) | | 0x40 | SET_RADIO_POWER (0x04) | ||
+ | Sets the radio amplifier output power. Possible values: | ||
+ | ^ Value ^ Power ^ | ||
+ | | 0 | -18dBm | ||
+ | | 1 | -12dBm | ||
+ | | 2 | -6dBm | | ||
+ | | 3 | 0dBm | | ||
==== Configure auto retry (ARD/ARC) ==== | ==== Configure auto retry (ARD/ARC) ==== | ||
Line 117: | Line 126: | ||
| 0x0F | 4000us | | 0x0F | 4000us | ||
^ Value ^ Ack payload length ^ | ^ Value ^ Ack payload length ^ | ||
| 0x80 | 0Byte | | | 0x80 | 0Byte | | ||
Line 128: | Line 136: | ||
By default ARD=32Bytes (0xA0) and ARC=3. | By default ARD=32Bytes (0xA0) and ARC=3. | ||
- | ==== Continuous carrier mode ==== | + | ==== Auto ACK configuration |
Line 151: | Line 159: | ||
| 0 | Dongle working normally (default) | | | 0 | Dongle working normally (default) | | ||
| Not 0 | Dongle in continuous carrier mode | | | Not 0 | Dongle in continuous carrier mode | | ||
+ | ==== Channels scanning ==== | ||
==== Launch bootloader ==== | ==== Launch bootloader ==== |
