doc:crazyradio:usb:index [2017-06-22 09:28] arnaud [Radio configuration] |
doc:crazyradio:usb:index [2020-05-12 14:12] kimberly |
====== USB and Radio protocol of the Crazyradio dongle ====== | ====== USB and Radio protocol of the Crazyradio dongle ====== | ||
Line 178: | Line 184: | ||
| 0x40 | START_SCAN_CHANNELS (0x21) | Start | Stop | Length | | 0x40 | START_SCAN_CHANNELS (0x21) | Start | Stop | Length | ||
- | | 0xC0 | GET_SCAN_CHANNELS (0x21) | + | | 0xC0 | GET_SCAN_CHANNELS (0x21) |
Scan a range of channels and compile a list of channel from which an ACK has been received. The command START_SCAN_CHANNELS should be executed first with start being the first scanned channel and stop the last one. Those should be within 0 to 125. The data is the packet payload sent on each channel, it should be at least one byte long. | Scan a range of channels and compile a list of channel from which an ACK has been received. The command START_SCAN_CHANNELS should be executed first with start being the first scanned channel and stop the last one. Those should be within 0 to 125. The data is the packet payload sent on each channel, it should be at least one byte long. | ||
Line 184: | Line 190: | ||
All parameters, except the channel, are used unmodified during the scan. If the data rate is set to 2MBPs the scan is done every second channel. To get the list of channels that answered, GET_SCANN_CHANNELS should be called just after a scan. Up to 63 bytes are returned corresponding to up to 63 channels on which the packet was acknowledged. | All parameters, except the channel, are used unmodified during the scan. If the data rate is set to 2MBPs the scan is done every second channel. To get the list of channels that answered, GET_SCANN_CHANNELS should be called just after a scan. Up to 63 bytes are returned corresponding to up to 63 channels on which the packet was acknowledged. | ||
- | Note: After scanning, the channel will be set to the last scanned channel. | + | <WRAP center round info> |
+ | //**Note**// | ||
+ | After scanning, the channel will be set to the last scanned channel. | ||
+ | On some platform, an empty scan will return a buffer of 64 bytes. This is though to be a USB host implementation bug, see [[https:// | ||
==== Launch bootloader ==== | ==== Launch bootloader ==== |
