User Tools
Site Tools
doc:crazyradio:usb:index
Differences
Link to this comparison view
Next revision
Previous revision
doc:crazyradio:usb:index [2013-07-11 17:54]
arnaud [Radio protocol]
doc:crazyradio:usb:index [2020-05-12 14:12] (current)
Line 1: Line 1:
-====== Usb and Radio protocol of the Crazyradio dongle ======+<WRAP center round important 60%>
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
 +</WRAP>
-The Crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. The radio communication is done using the Nordic "Enhanced ShockBurst™" packet protocol in PTX mode with acknoledge. Variable size packet, from 1 to 32 bytes, can be send and acknoledged by the copter. The acknoledgement packet can contains a payload from 0 to 32Bytes.
-This page document the protocol used in the version 0.40 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible.+
 +====== USB and Radio protocol of the Crazyradio dongle ======
 +The Crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. The radio communication is done using the Nordic "Enhanced ShockBurst™" packet protocol in PTX mode with acknowledge. Variable sized packet, from 1 to 32 bytes, can be send and acknowledged by the copter. The acknowledgement packet can contain a payload from 0 to 32 Bytes.
 +This page documents the protocol used in version 0.52 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible
 +===== Radio configuration =====
 +Crazyradio is configured in PTX mode. It can communicate with Nordic chips compatible with the nrf24L family (at least nrf24L01p, nRF51 and nRF52 tested). In order to communicate with the Crazyradio the target has to be configure correctly:
 +  * PRX mode
 +  * One active pipe with the address configured in the Crazyradio dongle, by default it is 0xE7E7E7E7E7
 +  * 5 byte address
 +  * Dynamic payload length enable
 +  * Payload with ack enable
 +The Crazyflie is already configured that way. The relevant source code can be seen in [[https://github.com/bitcraze/crazyflie-firmware/blob/02a2b6d48800334ed455144d9061226418fab7b7/hal/src/radiolink.c#L163|radiolink.c]].
 ===== USB protocol ===== ===== USB protocol =====
-The USB devices have the VID/PID couple 0x1915/0x7777.+The USB devices has the VID/PID couple 0x1915/0x7777.
 | EP0 | Control | Control endpoint. Used to configure the dongle | | EP0 | Control | Control endpoint. Used to configure the dongle |
Line 14: Line 32:
 ==== Data transfer ==== ==== Data transfer ====
-The radio dongle being configured in PTX (emmiter) mode it sends packet to the copter and waits for the acknowledge. The acknowledge can contains Payload which is the mean to receive data. If the auto acknowledge is disable there is no IN transaction.+When the radio dongle is configured to use PTX (emitter) mode it sends packet to the copter and waits for the acknowledge. The acknowledge can contain payload which is the mean to receive data. If the auto acknowledge is disabled there is no IN transaction.
-To send a packet the following sequence must be followes+To send a packetthe following sequence must be followed
-  * Send the packet to EP1_OUT. Its length should be between 1 to 32Bytes +  * Send the packet to EP1_OUT. Its length should be between 1 to 32 Bytes
-  * Read the ACK from EP1_IN. The first byte is the transfers status and the following bytes are the content of the ACK payload, if any.+  * Read the ACK from EP1_IN. The first byte is the transfer status and the following bytes are the content of the ACK payload, if any.
 <ditaa> <ditaa>
Line 36: Line 54:
 ^ Status  Bit   ^ Role                    ^ ^ Status  Bit   ^ Role                    ^
-| 4..7          | Number of retransmition |+| 4..7          | Number of retransmission |
 | 2..3          | Reserved                | | 2..3          | Reserved                |
 | 1             | Power detector          | | 1             | Power detector          |
-| 0             Ack received            |+| 0             ACK received            |
 ==== Dongle configuration and functions summary ==== ==== Dongle configuration and functions summary ====
Line 48: Line 66:
 |          0x40 | SET_RADIO_CHANNEL (0x01)   | channel  | Zero   | Zero    | None    | |          0x40 | SET_RADIO_CHANNEL (0x01)   | channel  | Zero   | Zero    | None    |
 |          0x40 | SET_RADIO_ADDRESS (0x02)   | Zero     | Zero   | 5       | Address | |          0x40 | SET_RADIO_ADDRESS (0x02)   | Zero     | Zero   | 5       | Address |
-|          0x40 | SET_DATA_RATE (0x03)       Datarate | Zero   | Zero    | None    |+|          0x40 | SET_DATA_RATE (0x03)       Data rate | Zero   | Zero    | None    |
 |          0x40 | SET_RADIO_POWER (0x04)     | Power    | Zero   | Zero    | None    | |          0x40 | SET_RADIO_POWER (0x04)     | Power    | Zero   | Zero    | None    |
 |          0x40 | SET_RADIO_ARD (0x05)       | ARD      | Zero   | Zero    | None    | |          0x40 | SET_RADIO_ARD (0x05)       | ARD      | Zero   | Zero    | None    |
Line 63: Line 81:
-The nrf24L chips provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if not the command will be ignored).+The nRF24LU1 chip provides 126 Channels of 1MHz from 2400MHz to 2525MHz. The channel parameter shall be between 0 and 125 (if notthe command will be ignored).
-The radio channel is set as soon as the USB setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2.+The radio channel is set as soon as the USB setup transaction is completedwhich takes about 1ms. The new frequency is going to be used for the following transferred packets. The default value for the radio channel is 2.
 ==== Set radio address ==== ==== Set radio address ====
Line 74: Line 92:
 The packet sent by the radio contains a 5 bytes address. The same address must be configured in the receiver for the communication to work. The packet sent by the radio contains a 5 bytes address. The same address must be configured in the receiver for the communication to work.
-The address must follow the requirement of the section 6.4.3.2 of the nRF24LU1 documentation:+The address must follow the requirement of section 6.4.3.2 of the nRF24LU1 documentation:
 <code> <code>
Line 84: Line 102:
 The default address is 0xE7E7E7E7E7. The default address is 0xE7E7E7E7E7.
-==== Set datarate ====+==== Set data rate ====
 ^ bmRequestType ^ bRequest                 ^ wValue   ^ wIndex ^ wLength ^ data    ^ ^ bmRequestType ^ bRequest                 ^ wValue   ^ wIndex ^ wLength ^ data    ^
-Possible values for the datarate+Possible values for the data rate
-^ Value ^ Radio datarate ^+^ Value ^ Radio data rate ^
 |     0 | 250Kbps        | |     0 | 250Kbps        |
 |     1 | 1MBps          | |     1 | 1MBps          |
Line 115: Line 133:
 |          0x40 | SET_RADIO_ARC (0x06)     | ARC      | Zero   | Zero    | None    | |          0x40 | SET_RADIO_ARC (0x06)     | ARC      | Zero   | Zero    | None    |
-After sending a packet the radio automatically waits for an acknowledge. ARD and ARC permits to configure the delay the radio waits for the acknowledge and the number of time the transfer will be retried in case the acknowledge is not received in that delay.+After sending a packet the radio automatically waits for an acknowledge. ARD and ARC permit to configure the delay the radio waits for the acknowledge and the number of times the transfer will be retried in case the acknowledge is not received in that delay.
-The delay ARD depends of the length, in second, of the ack packed. This depends of the datarate and the Payload length contained in the Ack packet. The ARD can be configured either by step of 250us or by ack payload length. If the ack payload length is configured the time will be recalculated automatically even if the datarate is changed. To set the Ack payload lenght the bit 7 of Ard must be set (length | 0x80)+The delay ARD depends on the length, in seconds, of the ACK packet. This depends on the data rate and the payload length contained in the ACK packet. The ARD can be configured either by steps of 250us or by ACK payload length. If the ACK payload length is configuredthe time will be recalculated automatically even if the data rate is changed. To set the ACK payload length the bit 7 of ARD must be set (length | 0x80).
 Possible values for ARD: Possible values for ARD:
Line 126: Line 144:
 |  0x0F | 4000us         | |  0x0F | 4000us         |
-^ Value ^ Ack payload length ^+^ Value ^ ACK payload length ^
 |  0x80 | 0Byte              | |  0x80 | 0Byte              |
 |  0x81 | 1Byte              | |  0x81 | 1Byte              |
Line 132: Line 150:
 |  0xA0 | 32Bytes            | |  0xA0 | 32Bytes            |
-ARC configures the number of time the radio will retry a transfer if the Ack has not been received, it can be set from 0 to 15.+ARC configures the number of times the radio will retry a transfer if the ACK has not been received, it can be set from 0 to 15.
 By default ARD=32Bytes (0xA0) and ARC=3. By default ARD=32Bytes (0xA0) and ARC=3.
Line 141: Line 159:
 |          0x40 | ACK_ENABLE (0x10)        | Active   | Zero   | Zero    | None    | |          0x40 | ACK_ENABLE (0x10)        | Active   | Zero   | Zero    | None    |
-By default Crazyradio is configured with auto ack enableIt means that after transmiting a packet the radio waits for an acknoledge from the receiver. This setting permits to deactivate waiting for the Ack packet so that the packet will be sent only one time and there are no guarantee that it has been correctly received.+By default, the Crazyradio is configured with auto ACK enabledThis means that after transmitting a packetthe radio waits for an acknowledge from the receiver. This setting permits to deactivate waiting for the ACK packet so that the packet will be sent only one time and there is no guarantee that it has been correctly received.
 ^ Active values ^ Meaning                   ^ ^ Active values ^ Meaning                   ^
-| 0             | Auto ack deactivated      | +| 0             | Auto ACK deactivated      |
-| Not 0         | Auto ack enable (default) |+| Not 0         | Auto ACK enable (default) |
 ==== Continuous carrier mode ==== ==== Continuous carrier mode ====
Line 152: Line 170:
 |          0x40 | SET_CONT_CARRIER (0x20)  | Active   | Zero   | Zero    | None    | |          0x40 | SET_CONT_CARRIER (0x20)  | Active   | Zero   | Zero    | None    |
-The nRF24L radio chip provides a test mode in which a continous non-modulated sine wave is emited. This permits, among other things, to test the quality of the RF elements of the board. When this mode is activated the radio dongle does not transmit any packets.+The nRF24L radio chip provides a test mode in which a continuous non-modulated sine wave is emitted. This permits, among other things, to test the quality of the RF elements of the board. When this mode is activated the radio dongle does not transmit any packets.
-while the continuous carrier mode is active it is possible to set channel and power to change the frequency and power of the emitted wave.+While the continuous carrier mode is activeit is possible to set channel and power to change the frequency and power of the emitted wave.
Line 166: Line 184:
 |          0x40 | START_SCAN_CHANNELS (0x21) | Start    | Stop   | Length  | Packet  | |          0x40 | START_SCAN_CHANNELS (0x21) | Start    | Stop   | Length  | Packet  |
-|          0xC0 | GET_SCAN_CHANNELS (0x21)   | Zero     | Zero   63      | Result  |+|          0xC0 | GET_SCAN_CHANNELS (0x21)   | Zero     | Zero   64      | Result  |
 +Scan a range of channels and compile a list of channel from which an ACK has been received. The command START_SCAN_CHANNELS should be executed first with start being the first scanned channel and stop the last one. Those should be within 0 to 125. The data is the packet payload sent on each channel, it should be at least one byte long.
-Scan a range of channels and compile a list of channel from which an ack has been received. The command START_SCAN_CHANNELS should be executed first with start being the first scanned channel and stop the last oneThose should be within 0 to 125. The data is the packet payload sent on each channel, it should be at least one byte long.+All parameters, except the channel, are used unmodified during the scanIf the data rate is set to 2MBPs the scan is done every second channel. To get the list of channels that answeredGET_SCANN_CHANNELS should be called just after a scan. Up to 63 bytes are returned corresponding to up to 63 channels on which the packet was acknowledged.
-All parametersexcept the channel, are used unmodified during the scan. If the datarate is set to 2MBPs the scan is done every second channel. To get the list of channel that answered GET_SCANN_CHANNELS should be called just after scanUp to 63 bytes are returned corresponding to up to 63 channels on which the packet was acknowledged.+<WRAP center round info>
 +//**Note**//
 +After scanning, the channel will be set to the last scanned channel.
 +</WRAP>
 +<WRAP center round important>
 +//**Warning**//
 +On some platform, an empty scan will return a buffer of 64 bytes. This is though to be a USB host implementation bug, see [[https://github.com/bitcraze/crazyradio-firmware/issues/9|ticket #9]] in the Crazyradio firmware project. If a buffer of more than 63 bytes is returned, it means that no channel have been received.
 +</WRAP>
-Note. After scanning the channel will be let to the last scanned channel.
 ==== Launch bootloader ==== ==== Launch bootloader ====
Line 179: Line 205:
 |          0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero     | Zero   | Zero    | None    | |          0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero     | Zero   | Zero    | None    |
-This command is used to launch the Nordic semiconductor USB bootloader. After sending this command a USB reset shall be emitted which will trigger the dongle to start the bootloader. After sending this command the Dongle is only waiting for a USB reset which means that any other commands or data will be ignored.+This command is used to launch the Nordic semiconductor USB bootloader. After sending this commanda USB reset shall be emitted which will trigger the dongle to start the bootloader. After sending this commandthe Dongle is only waiting for a USB reset which means that any other commands or data will be ignored.
-The bootloader is pre-loaded by Nordic Semi. in the nRF24LU1 chip at the address 0x7800. The Crazyradio firmware will jump to it when the sequence LAUCH_BOOTLOADER following by a USB reset is executed. The bootloader will appear at VID/PID of 0x1915/0x0101. See nRF24LU1 datasheet for the bootloader documentation.+The bootloader is pre-loaded by Nordic Semi. in the nRF24LU1 chip at the address 0x7800. The Crazyradio firmware will jump to it when the sequence LAUCH_BOOTLOADER followed by a USB reset is executed. The bootloader will appear at VID/PID of 0x1915/0x0101. See nRF24LU1 datasheet for the bootloader documentation.
 A PC client for the bootloader is part of the Crazyflie ground station program. A PC client for the bootloader is part of the Crazyflie ground station program.
Line 187: Line 213:
 ===== Radio protocol ===== ===== Radio protocol =====
-The Crazyradio dongle is currently only operating in PTX mode. To get downlink from the copter the ACK payload is used, which means that data are received only when data are sent. In the case of Crazyflie, to have bidirectional communication even when no data is send, a null packet (0xff) is sent periodically to pull the downlink data stream.+The Crazyradio dongle is currently only operating in PTX mode. To get downlink from the copter the ACK payload is used, which means that data are received only when data are sent. In the case of Crazyflie, to have bidirectional communication even when no data is send, a null packet (0xff) is sent periodically to pull the downlink data stream.
 For Crazyflie the communication protocol is described in [[projects:crazyflie:firmware:comm_protocol|Communication protocol Overview]]. For Crazyflie the communication protocol is described in [[projects:crazyflie:firmware:comm_protocol|Communication protocol Overview]].
doc/crazyradio/usb/index.1373558072.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
