doc:lighthouse:bootloader [2019-03-10 12:11] arnaud [Bootloader protocol] |
doc:lighthouse:bootloader [2020-05-12 14:36] kimberly |
+ | https:// | ||
====== Lighthouse deck bootloader ====== | ====== Lighthouse deck bootloader ====== | ||
Line 113: | Line 123: | ||
===== Firmware versioning ===== | ===== Firmware versioning ===== | ||
- | The firmware is an iCE40 bitstream ((The bitstream format has been [[http:// | + | The firmware is an iCE40 bitstream ((The bitstream format has been [[http:// |
- | The version string format is a base 10 integer number in ascii indicating the version. For example " | + | The version string format is a base 10 integer number in ascii indicating the version. For example " |
In the context of the lighthouse firmware, versions >= 1 are released version and should be in parity (or handled) by the client connecting the board in order to boot the firmware. Versions <= 0 are development version and the intention is that the client will then boot it without further check. | In the context of the lighthouse firmware, versions >= 1 are released version and should be in parity (or handled) by the client connecting the board in order to boot the firmware. Versions <= 0 are development version and the intention is that the client will then boot it without further check. |
