doc:lighthouse:bootloader [2019-03-07 11:20] arnaud |
doc:lighthouse:bootloader [2020-03-05 20:52] kristoffer |
+ | https:// | ||
====== Lighthouse deck bootloader ====== | ====== Lighthouse deck bootloader ====== | ||
Line 9: | Line 19: | ||
- | There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate of 115200. | + | There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate |
+ | **Warning**: | ||
When using the UART, commands are sent on the RX line and answer will be sent back by the bootloader on the TX line. Since the bootloader and the Flash SPI bus are working much faster than the UART, there is no need for flow control. | When using the UART, commands are sent on the RX line and answer will be sent back by the bootloader on the TX line. Since the bootloader and the Flash SPI bus are working much faster than the UART, there is no need for flow control. | ||
Line 36: | Line 51: | ||
- | All numbers are expressed | + | All numbers are encoded |
Line 108: | Line 123: | ||
===== Firmware versioning ===== | ===== Firmware versioning ===== | ||
- | The firmware is an iCE40 bitstream ((The bitstream format has been [[http:// | + | The firmware is an iCE40 bitstream ((The bitstream format has been [[http:// |
- | The version string format is a base 10 integer number in ascii indicating the version. For example " | + | The version string format is a base 10 integer number in ascii indicating the version. For example " |
In the context of the lighthouse firmware, versions >= 1 are released version and should be in parity (or handled) by the client connecting the board in order to boot the firmware. Versions <= 0 are development version and the intention is that the client will then boot it without further check. | In the context of the lighthouse firmware, versions >= 1 are released version and should be in parity (or handled) by the client connecting the board in order to boot the firmware. Versions <= 0 are development version and the intention is that the client will then boot it without further check. |
