doc:lighthouse:setup [2019-03-14 14:34] kimberly [Setting up SteamVR without Head Mounted Display] |
doc:lighthouse:setup [2019-04-04 11:29] arnaud [Setting up SteamVR without Head Mounted Display] |
Line 15: | Line 15: | ||
+ | For the floor to be flat, it is good to start steamVR with the controller placed on the floor. The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the master base station (the one in Mode B) will be at the origin of the space. The Z axis will be the vector normal to the base station window, pointing toward the inside of the base station and rotated around X to be parallel with the floor. | ||
- | The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the slave base station (the one in Mode A or C) will be at the origin of the space and the Z axis will be normal to the base station window. | ||
Line 25: | Line 28: | ||
+ | Or this when running the script from the Crazyflie firmware repos: | ||
+ | $ python3 get_bs_position.py | ||
+ | Openning OpenVR | ||
+ | python3: Relink `/ | ||
+ | Segmentation fault (core dumped) | ||
Then you are maybe missing some essential packages for openvr: | Then you are maybe missing some essential packages for openvr: | ||
Line 31: | Line 43: | ||
* libvulkan-dev | * libvulkan-dev | ||
* libsdl2-dev | * libsdl2-dev | ||
+ | On Ubuntu: | ||
+ | $ sudo apt-get install libudev-dev | ||
+ | $ python3 -m pip uninstall openvr | ||
+ | $ python3 -m pip install openvr | ||
if this still doesn' | if this still doesn' | ||
[[https:// | [[https:// | ||
+ | **Troubleshooting²** | ||
+ | # cat > / | ||
+ | KERNEL==" | ||
+ | EOF | ||
Line 52: | Line 85: | ||
- | python | + | python3 |
Line 74: | Line 107: | ||
- | Copy the last two lines and, on the computer or virtual machine you use for Crazyflie development, | + | Copy the last two lines and, on the computer or virtual machine you use for Crazyflie development, |
<code c> | <code c> | ||
- | // # | + | // #ifndef DISABLE_LIGHTHOUSE_DRIVER |
+ | // #endif | ||
baseStationGeometry_t baseStationsGeometry[] = { | baseStationGeometry_t baseStationsGeometry[] = { |
