doc:lighthouse:setup [2019-03-10 12:20] arnaud |
doc:lighthouse:setup [2019-11-29 15:29] kristoffer |
Line 5: | Line 5: | ||
The lighthouse deck allows to use the HTC-Vive/ | The lighthouse deck allows to use the HTC-Vive/ | ||
- | The VR computer must have [[https:// | + | The VR computer must have [[https:// |
- | In order to setup the system you must also be able to compile a custom firmware for your Crazyflie and to program your Crazyflie 2.X. To do so youcan | + | In order to setup the system you must also be able to compile a custom firmware for your Crazyflie and to program your Crazyflie 2.X. To do so you can follow the [[https:// |
===== Setting up SteamVR without Head Mounted Display ===== | ===== Setting up SteamVR without Head Mounted Display ===== | ||
Line 15: | Line 15: | ||
- | The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the slave base station (the one in Mode A or C) will be at the origin of the space and the Z axis will be normal to the base station window. | + | <WRAP center round info> |
+ | **OSX** | ||
+ | The osx implementation seems to be a bit shaky, but it is possible to make it work. I used the " | ||
+ | For the floor to be flat, it is good to start steamVR with the controller placed on the floor. | ||
+ | **Troubleshooting** | ||
+ | If you get the following message when running the tracker_test.py script of the tutorial (step 16): | ||
+ | Or this when running the script from the Crazyflie firmware repos: | ||
+ | $ python3 get_bs_position.py | ||
+ | Openning OpenVR | ||
+ | python3: Relink `/ | ||
+ | Segmentation fault (core dumped) | ||
+ | Then you are maybe missing some essential packages for openvr: | ||
+ | * libudev-dev | ||
+ | * libvulkan-dev | ||
+ | * libsdl2-dev | ||
+ | On Ubuntu: | ||
+ | $ sudo apt-get install libudev-dev | ||
+ | $ python3 -m pip uninstall openvr | ||
+ | $ python3 -m pip install openvr | ||
+ | if this still doesn' | ||
+ | [[https:// | ||
+ | **Troubleshooting²** | ||
+ | # cat > / | ||
+ | KERNEL==" | ||
+ | EOF | ||
===== Setting up the space origin and orientation with an HMD ===== | ===== Setting up the space origin and orientation with an HMD ===== | ||
Line 34: | Line 101: | ||
- | python | + | python3 |
Line 56: | Line 123: | ||
- | Copy the last two lines and, on the computer or virtual machine you use for Crazyflie development, | + | Copy the last two lines and, on the computer or virtual machine you use for Crazyflie development, |
<code c> | <code c> | ||
- | // # | + | // #ifndef DISABLE_LIGHTHOUSE_DRIVER |
+ | // #endif | ||
baseStationGeometry_t baseStationsGeometry[] = { | baseStationGeometry_t baseStationsGeometry[] = { | ||
Line 75: | Line 144: | ||
===== Space orientation, | ===== Space orientation, | ||
- | The following rotation is done from the OpenVR space to the Crazyflie | + | |
Line 83: | Line 150: | ||
- | This allows to easily orient the Crazyflie when setting up the system | + | The Lighthouse deck has 4 receivers and can recover its orientation. The Crazyflie |
+ | ===== The number of basestations and frame synchronization ===== | ||
- | While the Lighthouse deck has 4 receiver | + | The lighthouse deck works with one or two V1 basestations but the estimated position will be better |
- | The safest way to verify | + | The protocol for the lighthouse is composed |
+ | Due to the design of the lighthouse protocol, visibility | ||
- | Once you have located X positive, you can test if the positioning is working by starting the Crazyflie facing X and using the clients " | ||
