doc:lighthouse:setup [2019-04-02 17:29] arnaud |
doc:lighthouse:setup [2019-11-29 15:29] kristoffer |
Line 15: | Line 15: | ||
+ | **OSX** | ||
+ | The osx implementation seems to be a bit shaky, but it is possible to make it work. I used the " | ||
For the floor to be flat, it is good to start steamVR with the controller placed on the floor. The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the master base station (the one in Mode B) will be at the origin of the space. The Z axis will be the vector normal to the base station window, pointing toward the inside of the base station and rotated around X to be parallel with the floor. | For the floor to be flat, it is good to start steamVR with the controller placed on the floor. The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the master base station (the one in Mode B) will be at the origin of the space. The Z axis will be the vector normal to the base station window, pointing toward the inside of the base station and rotated around X to be parallel with the floor. | ||
Line 28: | Line 44: | ||
+ | Or this when running the script from the Crazyflie firmware repos: | ||
+ | $ python3 get_bs_position.py | ||
+ | Openning OpenVR | ||
+ | python3: Relink `/ | ||
+ | Segmentation fault (core dumped) | ||
Then you are maybe missing some essential packages for openvr: | Then you are maybe missing some essential packages for openvr: | ||
Line 34: | Line 59: | ||
* libvulkan-dev | * libvulkan-dev | ||
* libsdl2-dev | * libsdl2-dev | ||
+ | On Ubuntu: | ||
+ | $ sudo apt-get install libudev-dev | ||
+ | $ python3 -m pip uninstall openvr | ||
+ | $ python3 -m pip install openvr | ||
if this still doesn' | if this still doesn' | ||
[[https:// | [[https:// | ||
+ | **Troubleshooting²** | ||
+ | # cat > / | ||
+ | KERNEL==" | ||
+ | EOF | ||
Line 55: | Line 101: | ||
- | python | + | python3 |
Line 98: | Line 144: | ||
===== Space orientation, | ===== Space orientation, | ||
- | The following rotation is done from the OpenVR space to the Crazyflie | + | |
Line 106: | Line 150: | ||
- | This allows to easily orient the Crazyflie when setting up the system | + | The Lighthouse deck has 4 receivers and can recover its orientation. The Crazyflie |
+ | ===== The number of basestations and frame synchronization ===== | ||
- | While the Lighthouse deck has 4 receiver | + | The lighthouse deck works with one or two V1 basestations but the estimated position will be better |
- | The safest way to verify | + | The protocol for the lighthouse is composed |
+ | Due to the design of the lighthouse protocol, visibility | ||
- | Once you have located X positive, you can test if the positioning is working by starting the Crazyflie facing X and using the clients " | ||
