User Tools
Site Tools
doc:lighthouse:setup
Differences
Link to this comparison view
Next revision
Previous revision
doc:lighthouse:setup [2019-04-03 15:42]
macke
doc:lighthouse:setup [2019-04-04 11:24]
arnaud [Setting up SteamVR without Head Mounted Display]
Line 28: Line 28:
 ''openvr.OpenVRError: b'VRInitError_Init_VRClientDLLNotFound' (error number 102)'' ''openvr.OpenVRError: b'VRInitError_Init_VRClientDLLNotFound' (error number 102)''
 +Or this when running the script from the Crazyflie firmware repos:
 +<code>
 +$ python3 get_bs_position.py
 +Openning OpenVR
 +python3: Relink `/lib/x86_64-linux-gnu/libudev.so.1' with `/lib/x86_64-linux-gnu/librt.so.1' for IFUNC symbol `clock_gettime'
 +Segmentation fault (core dumped)
 +</code>
 Then you are maybe missing some essential packages for openvr: Then you are maybe missing some essential packages for openvr:
Line 34: Line 43:
   * libvulkan-dev   * libvulkan-dev
   * libsdl2-dev   * libsdl2-dev
 +On Ubuntu:
 +<code>
 +$ sudo apt-get install libudev-dev  libvulkan-dev  libsdl2-dev
 +$ python3 -m pip uninstall openvr
 +$ python3 -m pip install openvr
 +</code>
 if this still doesn't work, please check this forum-thread for other options: if this still doesn't work, please check this forum-thread for other options:
 [[https://github.com/cmbruns/pyopenvr/issues/30]] [[https://github.com/cmbruns/pyopenvr/issues/30]]
 +</WRAP>
 +<WRAP center round info>
 +**Troubleshooting²**
 +When running SteamVR on Linux, by default the access right to USB device might not be configured right. If you have problem connecting the tracker/controller/HMD you can add a udev rules that gives full access to any USB Valve hardware to all users on your system:
 +<code>
 +# cat > /etc/udev/rules.d/99-steamvr.rules << EOF
 +KERNEL="hidraw*", ATTRS{idVendor}=="28de", MODE=="0666"
 +EOF
 +</code>
 +You may need to restart SteamVR to see the connected devices.
 </WRAP> </WRAP>
doc/lighthouse/setup.txt · Last modified: 2020-05-12 14:35 by kimberly
