doc:lighthouse:setup [2019-04-04 11:24] arnaud [Setting up SteamVR without Head Mounted Display] |
doc:lighthouse:setup [2019-11-29 14:20] kristoffer |
Line 15: | Line 15: | ||
+ | **OSX** | ||
+ | The osx implementation seems to be a bit shaky, but it is possible to make it work. I used the " | ||
For the floor to be flat, it is good to start steamVR with the controller placed on the floor. The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the master base station (the one in Mode B) will be at the origin of the space. The Z axis will be the vector normal to the base station window, pointing toward the inside of the base station and rotated around X to be parallel with the floor. | For the floor to be flat, it is good to start steamVR with the controller placed on the floor. The only difference with an HMD setup is the orientation of the space: with an HMD the space will be oriented when you setup the room. Without an HMD the master base station (the one in Mode B) will be at the origin of the space. The Z axis will be the vector normal to the base station window, pointing toward the inside of the base station and rotated around X to be parallel with the floor. | ||
Line 63: | Line 79: | ||
# cat > / | # cat > / | ||
- | KERNEL=" | + | KERNEL==" |
EOF | EOF | ||
Line 128: | Line 144: | ||
===== Space orientation, | ===== Space orientation, | ||
- | The following rotation is done from the OpenVR space to the Crazyflie | + | |
Line 136: | Line 150: | ||
- | This allows to easily orient the Crazyflie when setting up the system with an HMD. | + | The Lighthouse deck has 4 receivers |
- | While the Lighthouse deck has 4 receiver | + | |
- | The safest way to verify the orientation | + | |
- | {{:doc:lighthouse: | + | |
- | Once you have located X positive, you can test if the positioning is working by starting the Crazyflie facing X and using the clients " | + | |
