doc:lps:tdoa3:protocol [2018-05-02 14:38] kristoffer |
doc:lps:tdoa3:protocol [2020-05-12 14:08] (current) kimberly |
- | ====== TDoA Anchor protocol V3 (experimental) ====== | ||
- | <WRAP center round tip 80%> | ||
- | **NOTE** | ||
- | This is work in progress. The specifications on this page may change at any time without backwards compatibility. | ||
- | This page describes the [[doc: | + | ====== |
- | ===== System architecture | + | ===== Design goals ===== |
- | The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system | + | The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system |
Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position. | Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position. | ||
Line 20: | Line 16: | ||
===== Packet scheduling ===== | ===== Packet scheduling ===== | ||
- | Packets are transmitted at random times and collisions are handled by the system. | + | Packets are transmitted at random times and collisions are handled by the receiving party. |
===== Packet format ===== | ===== Packet format ===== | ||
- | There is only one packet format. | ||
- | Packet | + | Packet |
7 bytes | 7 bytes | ||
- | 8 bits 8 bits 32 bits 8 bits | + | 8 bits 8 bits 32 bits 8 bits |
- | Header | + | Header |
Line 46: | Line 40: | ||
Remote anchor data: | | Remote anchor data: | | ||
Line 60: | Line 54: | ||
* **rxTimeStamp: | * **rxTimeStamp: | ||
* **distance: | * **distance: | ||
+ | * **LPP data:** See [[doc: | ||
===== Tag implementation ===== | ===== Tag implementation ===== | ||
- | A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive | + | A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the timestamps |
+ | ===== Calculating TDoA ===== | ||
+ | [[doc: | ||
