doc:lps:tdoa [2017-12-18 15:33] arnaud |
doc:lps:tdoa [2017-12-19 10:35] arnaud |
Line 5: | Line 5: | ||
To get your Crazyflie to fly with TDoA position estimation you need to: | To get your Crazyflie to fly with TDoA position estimation you need to: | ||
+ | - Flash the latest master branch of the [[https:// | ||
- Setup your anchors to maximize the size of the convex hull formed by the anchor. This is best achieved by placing 8 anchors on the corners of a [[https:// | - Setup your anchors to maximize the size of the convex hull formed by the anchor. This is best achieved by placing 8 anchors on the corners of a [[https:// | ||
- Configure your system following the [[https:// | - Configure your system following the [[https:// |
