doc:lps:tdoa [2017-12-19 10:35] arnaud |
doc:lps:tdoa [2021-06-24 16:54] (current) kimberly |
==== Using TDoA mode ==== | ==== Using TDoA mode ==== | ||
+ | This page is outdated and TDoA is now part of the standard functionality. | ||
The loco positioning system TDoA mode allows a tag, ie. the Crazyflie 2.0, to find its position only by listening to the packets transmitted by the anchors. This has the advantage of not putting any hard-limit to the number of tags since adding tags does not add bandwidth requirement to the positioning radios. | The loco positioning system TDoA mode allows a tag, ie. the Crazyflie 2.0, to find its position only by listening to the packets transmitted by the anchors. This has the advantage of not putting any hard-limit to the number of tags since adding tags does not add bandwidth requirement to the positioning radios. |
