Next revision Both sides next revision | |||
doc:lps:toda3 [2018-05-11 15:04] kristoffer created |
doc:lps:toda3 [2018-05-11 15:06] kristoffer |
- | The TDoA3 mode is experimental and the code is unstable or might not yet work at all! | + | <WRAP center round tip 80%> |
+ | **NOTE** | ||
+ | The TDoA3 mode is experimental and the code is unstable or might not yet work at all | ||
To try it out you will have to do the following: | To try it out you will have to do the following: |
