doc:lps:toda3 [2018-05-11 15:04] kristoffer created |
doc:lps:toda3 [2018-08-22 14:44] kristoffer |
- | The TDoA3 mode is experimental and the code is unstable or might not yet work at all! | + | <WRAP center round tip 80%> |
+ | **NOTE** | ||
+ | The TDoA3 mode is experimental. The protocol | ||
+ | ===== Compile and flash ===== | ||
To try it out you will have to do the following: | To try it out you will have to do the following: | ||
- | ===== The LPS Nodes ===== | + | ==== The Crazyflie |
- | * Get the latests source code for the firmware from [[https:// | + | |
+ | * Flash the Crazyflie with '' | ||
+ | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. | ||
+ | If you want to force the Crazyflie to use TDoA3 on startup, use the LPS_TDOA3_ENABLE=1 compile option | ||
* Compile | * Compile | ||
* Flash the nodes using '' | * Flash the nodes using '' | ||
+ | * Set anchor positions, see below. | ||
+ | ===== Setting anchor positions ===== | ||
+ | Anchor positions can be set by the python client but it only supports ids 0-7. If you want to use more anchors there is a tool that can be used in the lps-node-firmware repo. | ||
+ | The tool uses a Crazyflie as a bridge to transmit UWB messages to the anchors. When it is started it transmits positions for all anchors over and over, | ||
+ | * Create a file with your anchor positions, see tools/ | ||
+ | * Start the Crazyflie | ||
+ | * Pipe the position file into the tool using the URI of your copter '' | ||
+ | * Move the Crazyflie close to all anchors to transfer the positions | ||
+ | ===== Sniffing ===== | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | ||
+ | example: '' | ||
+ | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
+ | For instance '' | ||
+ | Recompile both Crazyflie and anchors with the LPS_LONGER_RANGE compile flag. | ||
+ | Example: '' | ||
+ | * Find the src/ | ||
+ | * Compile and flash | ||
+ | * Find the src/uwb.c file | ||
+ | * Locate the line where PREAMBLE_LENGTH_S is defined | ||
+ | * Change it to 1024 bits: #define PREAMBLE_LENGTH_S ( 1024 * 1017.63e-9 ) | ||
- | ===== The Crazyflie ===== | ||
