doc:lps:toda3 [2018-06-13 13:52] kristoffer |
doc:lps:toda3 [2018-10-31 18:21] kristoffer |
- | <WRAP center round tip 80%> | + | TDoA 3 is part of the official Crazyflie and LPS Node firmware releases since 2018.10. |
- | **NOTE** | + | |
- | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | + | |
- | To try it out you will have to do the following: | + | The Crazyflie |
+ | If you want to force the Crazyflie | ||
- | ===== The Crazyflie ===== | + | ==== The LPS Nodes ==== |
- | * Get the latest source code for the firmware from [[https:// | + | * Configure |
- | * Compile for TDoA3 and force the TDoA mode with '' | + | * Set anchor positions, see below. |
- | * Flash the Crazyflie with '' | + | |
- | ===== The LPS Nodes ===== | + | ===== Setting anchor positions ===== |
+ | Anchor positions can be set by the python client or the tool in the lps-node-firmware repo. | ||
+ | You might have to move the Crazyflie close to all anchors to transfer the positions from the Crazyflie. | ||
+ | ===== Sniffing ===== | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB and configure it to sniffer mode. | ||
+ | example: '' | ||
+ | ==== Time of flight and anchor to anchor distance | ||
- | * Compile | ||
- | * Configure the Nodes as anchors, and set the mode to TDoA 3 | ||
- | * Anchor positions can be set using the python client (0 - 7) but if you have more anchors you will have toools/ | ||
===== 2D positioning ===== | ===== 2D positioning ===== | ||
Line 27: | Line 48: | ||
Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
- | For instance '' | + | For instance '' |
+ | Recompile the Crazyflie firmware with the LPS_LONGER_RANGE compile flag. | ||
+ | Example: '' | ||
+ | * Find the src/ | ||
+ | * Compile and flash | ||
+ | * There is a configuration setting for the preamble length | ||
