doc:lps:toda3 [2018-06-13 13:54] kristoffer |
doc:lps:toda3 [2020-05-12 14:08] kimberly |
- | ====== TDoA 3 set up ====== | + | <WRAP center round important 60%> |
- | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// | |
- | <WRAP center round tip 80%> | + | |
- | **NOTE** | + | |
- | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | + | |
- | To try it out you will have to do the following: | ||
- | ===== The Crazyflie | + | ====== TDoA 3 set up ====== |
- | * Get the latest source code for the firmware | + | TDoA 3 is part of the official Crazyflie and LPS Node firmware |
- | * Compile for TDoA3 and force the TDoA mode with '' | + | |
- | * Flash the Crazyflie with '' | + | |
- | ===== The LPS Nodes ===== | + | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. |
+ | If you want to force the Crazyflie to use TDoA3 on startup, use the LPS_TDOA3_ENABLE=1 compile option | ||
- | * Compile | ||
- | * Anchor positions can be set using the python client | + | * Set anchor positions, see below. |
+ | ===== Setting anchor positions ===== | ||
+ | Anchor positions can be set by the python client | ||
+ | You might have to move the Crazyflie close to all anchors | ||
+ | All the anchors work in the same coordinate system, so you need to choose a common origin for your system. Try to expand your system step by step, testing it at each step to catch problem when they start to happen. | ||
===== 2D positioning ===== | ===== 2D positioning ===== | ||
Line 27: | Line 28: | ||
Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
- | For instance '' | + | For instance '' |
+ | Recompile the Crazyflie firmware with the LPS_LONGER_RANGE compile flag. | ||
+ | Example: '' | ||
+ | * Find the src/ | ||
+ | * Compile and flash | ||
+ | * There is a configuration setting for the preamble length | ||
+ | ===== Sniffing ===== | ||
+ | Sniffing the system is useful when you want to start digging into the radio messages exchanged between the anchor. It is a debug functionality. | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB and configure it to sniffer mode. | ||
+ | example: '' | ||
- | ===== Longer range ===== | + | example: '' |
- | In this mode the UWB bitrate is lower and the messages will reach longer. | + | ==== Time of flight |
- | Recompile both Crazyflie and anchors with the LPS_LONGER_RANGE compile flag. | + | By piping |
- | Example: '' | + | example: '' |
